V4 Front Axel Corrosion Bearing Water Damage
Discussion in 'Multistrada' started by Sharpedge, Oct 28, 2025 at 6:27 PM.
  1. Removing wheels to get tyres done. The front axel was a right pig to get out. This is what I found when I cleaned up the axel and whipped down the inside of the bearing. Bike is just over a year old and has done 5K miles. Surely this is not normal.
    Spacers on both sides have dark brown dirt corrosion marks that are not coming off with degreaser. Bearings do not turn very easily, they don’t feel gritty but again this is can’t be normal….can it?
    https://drive.google.com/file/d/1-aiQAPCpM9Uc2T4leo9oH27BQ1YI8lMM/view?usp=sharing
    I'll imbed a pic here if someone can tell me how it's done.
    #1 Sharpedge, Oct 28, 2025 at 6:27 PM
  2. The wheel spacers are notoriously difficult to keep clean and do permanently stain very quickly. Pretty sure the axle is aluminium and will corrode but after 12 months :thinkingface: that's a bit soon. Wheel bearings should be free to rotate. My cynical alter ego is thinking poor pre delivery preparation, not greased up. I always liberally re-grease the axle every time it comes out. The bearings are 'sealed for life' but I pack the outside and inside of the bearings and clean up after I've torqued the axle. That hopefully restricts water ingress. If the wheel bearings are shot, they should be a warranty replacement. Andy
  3. not great that.
  4. Grease the shaft, normal practice, the spindle you have looks dry as nuns ….
  5. Commiserations, any more signs of serious corrosion around lower part of the bike that you wouldn't expect to see after after 12 months/5k miles? I'm guessing you've owned it from new?
  6. Yup, had it since new and the rest of the bike looks ok as far as I have checked. Will be taking the back wheel off tomorrow after the front has been changed. I'm expecting the same thing with that axel! Think it is likely bad delivery prep as mentioned above. Will lube them up good and proper before they go back in.
  7. Do you ride a lot in bad weather ? Or dry miles only ....
