Front Brake Disc - Replacement Options
Discussion in '851 / 888' started by Richrox986, Nov 14, 2020.
  1. Having ridden a few hundred miles on my 888 it's clear the front discs are warped.
    EBC seem to be the cheapest option at £80 a side.
    Anything I should know or any guidance?
    Thanks
  2. I guess you have already checked the disc buttons are free / tried spinning them and cleaning them up ? Worth trying first if you haven't.
    £80 sounds a really good price for Ducati pattern floating EBC x series. They seem to have good bite / feel / power / modulation / wear / heat handling with the right pads on track. I can’t comment about low temp response / warm up on the road at low temps.
  3. Thanks Jon,
    I'm going to drop the wheel off and check out the discs and the calipers. I expect they could do with a recondition/service while I'm getting everything sorted.
