1200 DVT Front Oil Cooler Cowl Fitting
Discussion in 'Multistrada' started by Bjohnson, Nov 8, 2015.
  1. ive just fitted the Evotech oil and radiator guards, but I'm not sure if the oil cooler cowl has gone back on quite right, could some one post up a close up picture of the front of their DVT so I can compare?
    Everything has gone back on and lined up (screw holes, fit against other panels etc) but I've got a small gap between bottom of headlight and top of cowl that I didn't think was there before!!
    I'm going to take it all off again today, remove the oil cooler guard and refit to check fit without he guard, could all be correct but I'm not sure and now have creeping doubts!!
  2. Mines got a gap there and I don't have a guard fitted!
  3. thanks for checking.
    I removed it all again and still had the gap, so obviously the fitment of the Evotech guard is ok. I didn't spot the gap before I started fitting it, but I keep seeing it now!!!!
