fuel cap drain
Discussion in 'Technical Help' started by idrinkbeer, Jun 15, 2013.
  1. washed the 1098 the other day and when I went for fuel I noticed water in the recess beneath the fuel cap. anyhows the drain hole wasn't draining. I removed the left hand infill panel between tank and tail and there are two nipples,the rear one was stuffed and required drilling out. drain now working. worth checking as this could be a source of fuel contamination. cheers folks
