Fuel Pressure??? And other ????
Discussion in 'Technical Help' started by Pablo Pirate, Jan 6, 2013.
  1. Howdo!!!
    I've seen a few people running increased fuel pressure, is there any gains here???
    Also what's the limitation of the injectors???
    Finally, is there any gain from increasing the size/altering the Throttle bodies, any companies that do this sort of machining??
    Why asking?? Because it's one of those things sitting in the back of me head :rolleyes:
    Cheers Pablo
  2. in simple terms power is how much fuel and air you can get into an engine....and get it burnt correctly. bigger throttle bodies, turbos to force it in, big valves, bigger cams so the valves are open longer bigger or better shaped exhausts..........its all about having the correct match and combination between the lot really.
  3. hi Pabs
    increasing fuel presure can help if the injectors are running out of duration by getting more fuel in in less time ie if the injectors are running near their duty cycle limit -open almost all the time
    you can either fit larger injectors or up the pressure
    bigger boddie would only help if your head are out flowing the TBs unlikely in your case
    regard steve b
