Fuel Pump
Discussion in 'Supersport (1974-2007)' started by Lumbux, Sep 4, 2015.
  1. I was looking for a new fuel pump for my 400 supersport. I found a web site listing supersport pumps the same as pumps for Citroen BX and Peugeot 205 pumps. Anyone used these before?
  2. Nah...........do what I have been meaning to do......I'll help
  3. K?
  4. As long as the pressure is low it should be ok
  5. Fit a solid state Facet pump externally with an external filter (or two)........I worked out how to do it, just haven't done it yet because my pump is still working (at the moment) and I'm not getting inside the tank for the hell of it.....
  6. It's one of the things I have to do for my rebuild, can't remember the name of the pump, but it's a low pressure external one so that, like many here I can remove pump from tank. Also got FCRS so pressure has to be low to prevent flooding.
  7. Probably a Facet pump.........they do a 1 - 4 psi one.........(or in that range anyway).
  8. I think it is, as I got the recommendation on here
  9. I was looking at a vacume pump off a monster when mine goes down.
  10. I think I'll stick to an in tank pump, I've not got fairings to hide a pump behind. I'm just getting bits ready to do over winter, so no big rush, as always thanks for the help and update to follow
