just received this off this fine forum and then found my old one! so this one is up for sale. £295 delivered. thanks all. Will post photo tomorrow but its the same as: www.ducatiforum.co.uk/threads/garmin-590lm-and-navihalter-for-multistrada.63792/
If you're willing to split I'll give you £50 for the navihalter including the extra adapter that macker made. You can then sell the 590 to non multi owners. Regards Harry
Hi Harry sounds like a plan, but I'm away until next Monday on hols, will contact you via pm then. best Steve
I'll jump in and answer this as I fitted one to a hyoerstrada so should be the same. The following link describes all you need to know. http://hyperstrada.com/mechanical-technical/4148-satnav.html Not sure whether the one for sale already has the ducati plug on the end but if not you can either put one on or wire together using crimps/solder whatever. Hope that helped.
Probs better to let the Seller confirm this... but if you look at the link he put up with his initial post it shows the cradle and the wiring (and it has the ducati plug ready to plug straight into your wiring). It will need the bits to be able to bolt to the handlebars of the hyper... although there are other options. The 595 came with all the right bits from new so he may have them. If not I'll let you have mine once I fit the navihalter (which won't fit the hyoermotard).
