1199 Gear Position Sensor Location
Discussion in 'Panigale' started by Stever845, Mar 28, 2017.
  1. Hi Guys ,
    Where is the gear position sensor located i have a 2012 Panigali 1199s and i need to replace it , thanks in advance .
  2. Well I've found it and just changed it over for a new one no more issues .
  3. What was your symptoms ?
    I know this is a old thread but I was wondering if you had the same symptoms as me.
    I have a 899 which has just started to give me false gear readings in the lower gears. It seems to correct itself when I'm in 5th and 6th and it won't show neutral now either so I'm having to hold the clutch in to start it up and then stalls when I put the side stand down as it thinks it's in gear when it isn't.. Its starting to get bloody annoying.
