Hi as the title says one of the rose joints on the 916 has become very notchy. Is there an equivalent part I can get or is this a case of a duc specific part
Not sure about Ducati but I just tried to buy just the rose joint for my rc8. Couldn't get one on its own so had to buy a complete shift rod. If Ducati are anything like KTM then I expect it'll be the same and cost a bomb!
I'm not sure of the exact size but any good motorsport stockets will do metric rose joints I'd guess they are either M5 or maybe M6 off the top of mu bonce. i.e. www.mcgillmotorsports.co.uk (Powered by CubeCart) https://www.tyagiracing.com/products/M5-Right-Hand-Rose-Joints-Rod-Ends.html
Thanks Drinky, there was just a little bit of play in the rear one on the shift rod. I've replaced it, don't want any more crazy 5th gear false neutrals tipping into corners
I had the same problem on the 8 after fitting a QS, a little slack can really cause problems, it's sweet now I've tightened everything to within an inch of its life.
they are available from Ducati seperately but are a bit more than in those links. They're M6. One is RH thread, the other a LH...
