For Sale Gearbox Input Shaft And Gears 98 M900
Discussion in 'Parts, Accessories & Clothing For Sale' started by Nasher, Oct 9, 2016.
  1. I brought this shaft and gears on Ebay from CMF breakers in Lancashire back in July whilst I was collecting parts to rebuild the 900SS engine we're working on.
    The images are from the original auction.
    I ended up not using it as we discovered it was a gear on the output shaft causing issues.
    It was described as coming from a 1998 M900 and is in good useable condition.
    Some of the gears have small marks that you'd expect from some use, but none are chipped or badly scored. All the bearings are good and the engagement dogs are nice and square.
    £50 including postage anywhere in the UK.
    This Oil pump was also purchased from Ebay at about the same time and was described as coming from a 1993 M900.
    I only purchased it for the gear wheel as we were missing a gear from our pump.
    So obviously the gear shown in the image is no longer attached.
    £20 including postage anywhere in the UK.
    Thanks
    Nasher
