Put OEM exhaust back on the old girl. But Ive got this error. Now both lambdas have not been used since ...well ages and they were fine and working. Now I have an error. I think the one on the underside tube connects to loom behind the EXV. The one on the trombone bit between swingers and engine connects to loom on lhs near or above clutch slave (ish). can anyone confirm this? Because i'd forgotten and it was the only socket without anything plugged into it. Ta.
lambda 22.2, TPS 1.1 and the highly amusing T.WAT error Ill had jp dial on an old lappy but its gone tits up. I run macs at home. So I guess Im screwed. I'll look into it tomorrow.
S'okay. They're all cleared now. But my knees are killing me. Still can't get JPDaig to work. Cables fine, lights on on com cable. I know my com port but I hit connect and it just sits connecting with green bar doing fek all. No data on screen. Stuff it, time for my 'glass of wine' ...ahem...
Im going to. Faults cleared. Finish tomorrow. Just need to go and look for @Stu848 cotter pins now. Sounds weird with no termi on it.
No. Thats parts. Ive still gotta rid myself of a clutch and the full termi. Plus a few other odds n sods once i get the 11 ready. Then I'll fuck off again. Until i need something else.
@Nelson. Can you run this on a Mac? I'm currently trying (with not much luck) to run Windows on Parallels to see if i can get my Tune Ecu to connect to my ecu - my Android tab is not able to connect all of a sudden.
