Hi everyone, Need to buy a chain and sprocket kit for my 748. I'm sure this has been covered in previous threads, but the world of chains seems to be ever changing. I've only brought D.I.D before and haven't had a problem. But with cheaper c&s kits out there claiming to be just as good, is it worth it?
Stick with known quality brands like those already mentioned, keep it clean and lubed to get the best value and use out of it.
I find even cheap ones are fine so long as the gauge is ample - they ain't going to get out too easily anyhoo...
do you have a quick change sprocket carrier? I do on mine and use a renthal sprocket and was using a tsubaki chian , both of which lasted years. Only changed the chain as I didn't like the gold color and found a silver one ( can't remember the make but it looks better! )
Not sure if i have a "quick change carrier". I'm going to fit new chain and sprocket my self and haven't fitted one to a single swing arm before. Any heads up or tips would be appreciated!
