999 Got A Screw Loose!
Discussion in '749 / 999' started by Alastair_999, May 19, 2019.
  1. Ive got a screw loose...well actually it fell off. Anyone know where I can get the fairing bolt/fastener thingy nearest the gear shifter for an early 999.
  2. Do you mean the hanger/faring support that comes off of the crankcase?
  3. Hi. It’s literally just the fastener bit. From memory it’s a half twist to close Allen bolt and a bit of metal that sits on the frame lug. I’ve got No power in the garage so can’t check until morning.
  4. Ah. Found them online.dzus fasteners. £2 each. Thanks anyway. Should have not been lazy and done some research
  5. Hiya... I know this is a bit later than your post, but I also need to acquire a couple of similar fairing fasteners.. the dzus fasteners you describe.. mechanic lost one and I have just done the same...just disapperaed into thin air! Can you let me know your source ? Thanks.
  6. hopefully @Alastair_999 will pick this up - was on here 6 weeks ago.
  7. Thanks Chris
  8. are you sorted now.? Pm me if you want help
  9. All good thanks, found some on ebay
