Hazards On After Fitting New Indicator
Discussion in 'Technical Help' started by Oly, Sep 19, 2025 at 4:49 PM.
  1. just fitted some led indicators to my 2025 v4s streetfighter. went to check if i’d got the left and right in the right plugs it all
    i get is the hazard warning lights on. can’t turn them off .
    bike starts ok,
    any ideas ?
  2. just to add the new rear indicators are working ( with hazards ) so not a loose connection
  3. So, if I understand correctly. The front indicators are in hazard mode permanently as soon as the bike is switched on yet when you indicate right or left the correct rear responds but the front stay in hazard mode?
    Were the indicators you fitted Ducati parts?
  4. no all on hazards . th new ones are the rear and are ducati performance part for my bike.
    ive found out there is a cable going into the side of the left indicator/ mode assembly, i’ve pushed this in and it’s corrected the fault, i presume there is a plug inside the unit which is loose?
  5. Possibly the connection wasn’t fully home. if it’s good now, great :upyeah:
