749 Headlight Assembly
Discussion in '749 / 999' started by Talentless, Feb 14, 2020.
  1. Hi guys,
    I want to remove the headlight assembly from the frame, but the parts manual doesn't make it clear, does the instrument panel pop off and can I disconnect all the plugs in the headlight assembly or di I have to disconnect the wiring back in the frame?
    Thanks
  2. Undo the beam adj centre bolt, catch the spring behind.
    Pull the lamp forward from the rubbers. When the lamp is free, you can unplug the lamp and remove.
  3. done it, pulled the instrument display off, removed the plug, then removed the headlight to get to the screws holding the fuse box in. Triple clamps next.
  4. Talentless, I can send you a 999 factory repair manual if you want one for reference and common torque settings to the 749, its a full function PDF at 43MB so may be a stretch for email but I can put it on a disc and mail it
  5. thanks
    pm sent
