Healtech Servo Eliminator...
Discussion in 'Technical Help' started by AndrewS, Mar 1, 2021.
    • Lock Thread Lock Thread x 1
  1. The EXBV is there to comply with noise regs. Some will say it assists performance but my opinion is it is an emissions device. By fitting this the valve motor and cables can be junked. There will be no Mil on the dash as the device fools the ECU into identifying the motor is present. The EXBV is held in the open position by the spring but can also be lock wired. An added benefit is no Mils due to the EXBV failing due to corrosion.
  2. Thanks Chris.
