Thanks. Also, would you be able to help tell me about the rizoma dragbar its pros and cons. Moreover, there are 2 risers 42mm and 60mm which one would be appropriate and all revelant information. I’m 5’10 if you want to consider it for choosing one riser
welcome hridhay' Termi full system gets my vote as it comes with upmap, the others even if full systems require dyno work. Or if you just chaning the end can, you can go with whatever takes your visual fancy.
