Hey guys really need some help with this Had a run out on the bike last night to scrub some new tyres in 30 miles no problems Had a run through some menu settings to change suspension preloads and dtc settings now I get errors engine engine cranks over but wont start. Any ideas?
Update Ignition on engine errors on dash unplug fuel pump ignition on no engine error on dash Fuel pump issue?? bikes 63plate and not done 3000 miles.
Do you hear the fuel pump kick in? 3000 miles on a 63 plate suggests little to no useage. Has it sucked in some crud with the fuel?
Checked the clutch switch, side stand switch etc? Coincidences always occur with these thoroughbreds.!
Guys thanks for the reply's Its now sorted, new fuel pump relay. Nelly came good with the support and part, great guy #cornerspeed. Cheers
