Stored bike for winter now has bad starter solenoid and possibly a relay for the fuel injectors, they do not kick on when key is turned to on Kill switch is set to run, anyone have a diagram of the relays or know which one it is, or if it even could be a relay. Relay was my first thought
can't help with exact location of relay(s) but i'm sure someone will be along later- meanwhile this might help :- http://www.manualedereparatie.info/en/download/ducati-750-ss-2002-parts-list.html page 030 (item 13?) is probably the most helpful but couldn't find a downloadable wiring diagram. the large fuse on the same page might be worth checking also. We get a lot of damp and corrosion in the U.K. and sometimes just a removal or a 'wiggle' is all it takes
