Help Request Hyperstrada Indicator
Discussion in 'Hypermotard' started by Pierre88, Aug 5, 2018.
  1. If anyone can help I'd be extremely grateful. I'm due to go touring in five days and my offside rear indicator has stopped working. There is no power to the light unit. It appears to be an issue with the connector under the seat.
    Any ideas would be gratefully received.
    Pierre
  2. As a starter, disconnect the connector under the seat and clean as best you can, contact cleaner/alcohol/ brake cleaner etc and plug back together.
    Check there is voltage present with a test lamp/multimeter if that doesn't cure it.
  3. Many thanks. Will try.
