Hello, My bike has started making a high pitched whine, noticable above 2000rpm. the ptich goes up and down. This morning on the ride to work I noticed the needle on the rev counter was jumping about wildly. doesn't seem to do it in neutral with the clucth pulled in. Any ideas what could be wrong? Thanks
Clutch slip may account for the rev counter jumping? A problematic clutch could also account for the whining.
id start with looking at the clutch pressure plate bearing. My ss one was flogged and noisy. 10 min fix. Wouldn't account for the rev counter prob though...
Not sure it will account for the rev counter behaviour, but I had a high pitches whine like that which was in time with the engine speed and not the cams. In the end Rich at Louigi Moto correctly diagnosed shot main bearings. I was really surprised to say the least as the bike has only done 10k miles and had been regularly and scrupulosly maintained from new. Turned out that the crank had been over-shimmed by 0.25mm at the factory, enough to slowly ruin the main bearings over that time. Hope it's not that, just worth considering?
Hi All, sorry not been on here for a while. It's not the clutch bearing, although frictions plates needed replacing. Samuri - Main bearings seem likely, videos on youtube sound similar. (). do you know if that is the crankshaft bearing? there is no Main bearing listed in the parts fiche
No 32 and 33... same on many models 702.4.020.1A 2002 Ducati 748r Bearing HALF CRANKCASES 702.4.020.1A 2002 Ducati MH900e Bearing HALF CRANKCASES 702.4.020.1A 2002 Ducati MH900e Bearing HALF CRANKCASES 702.4.020.1A 2002 Ducati Monster 620 Bearing HALF CRANKCASES 702.4.020.1A 2002 Ducati Monster 750 Bearing HALF CRANKCASES 702.4.020.1A 2002 Ducati Monster 900 Bearing HALF CRANKCASES 702.4.020.1A 2002 Ducati Monster 900 Bearing HALF CRANKCASES 702.4.020.1A 2002 Ducati SuperSport 900 Sport Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati 748 Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati 749 Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati 998 Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati 999 Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati 999r Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati 999s Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati Monster 1000s Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati Monster 620 Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati Monster 620s Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati Monster 800s Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati Monster S4r Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati Multistrada 1000 Bearing Crankcase halves 702.4.020.1A 2003 Ducati ST2 Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati ST4 Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati ST4s Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati ST4s ABS Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati SuperSport 1000 Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati SuperSport 620 Sport Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati SuperSport 800 Bearing HALF CRANKCASES 702.4.020.1A 2003 Ducati SuperSport 800 Sport Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati 749 Dark Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati 749r Bearing CRANKCASE HALVES 702.4.020.1A 2004 Ducati 749s Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati 999 Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati 999r Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati 999s Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati Monster 1000 Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati Monster 620 Bearing CRANKCASE HALVES 702.4.020.1A 2004 Ducati Monster 800 Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati Monster S4r Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati Multistrada 1000 Bearing Crankcase halves 702.4.020.1A 2004 Ducati ST4s ABS Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati SuperSport 1000 Bearing HALF CRANKCASES 702.4.020.1A 2004 Ducati SuperSport 800 Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati 749 Dark Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati 749r Bearing CRANKCASE HALVES 702.4.020.1A 2005 Ducati 749s Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati 999r Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati 999s Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati Monster 1000 Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati Monster 1000s Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati Monster 400 Bearing CRANKCASE HALVES 702.4.020.1A 2005 Ducati Monster 620 Bearing CRANKCASE HALVES 702.4.020.1A 2005 Ducati Monster 620 Dark Bearing CRANKCASE HALVES 702.4.020.1A 2005 Ducati Monster S2r Bearing CRANKCASE HALVES 702.4.020.1A 2005 Ducati Monster S2r Dark Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati Monster S4r Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati ST3 Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati ST4 Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati ST4s ABS Bearing HALF CRANKCASES 702.4.020.1A 2005 Ducati SuperSport 1000 Bearing HALF CRANKCASES 702.4.020.1A 2006 Ducati 749r Bearing CRANKCASE HALVES 702.4.020.1A 2006 Ducati 749s Bearing CRANKCASE HALVES 702.4.020.1A 2006 Ducati 999 Bearing Crankcase halves 702.4.020.1A 2006 Ducati 999r Bearing Crankcase halves 702.4.020.1A 2006 Ducati 999r Xerox Bearing Crankcase halves 702.4.020.1A 2006 Ducati 999s Bearing Crankcase halves 702.4.020.1A 2006 Ducati Monster S2r 1000 Bearing Crankcase halves 702.4.020.1A 2006 Ducati Monster S4r Bearing Crankcase halves 702.4.020.1A 2006 Ducati Monster S4rs Bearing Half Crankcases 702.4.020.1A 2006 Ducati Multistrada 1000 Bearing Crankcase halves 702.4.020.1A 2006 Ducati Multistrada 1000s Bearing Crankcase halves 702.4.020.1A 2006 Ducati Multistrada 620 Bearing f.m.m.013216 Crankcase halves 702.4.020.1A 2006 Ducati Multistrada 620 Dark Bearing f.m.m.013216 Crankcase halves 702.4.020.1A 2006 Ducati SportClassic 1000 Paul Smart Limited Edition Bearing Crankcase halves 702.4.020.1A 2006 Ducati SportClassic 1000 Sport Bearing Crankcase halves 702.4.020.1A 2006 Ducati ST3 Bearing Crankcase halves 702.4.020.1A 2006 Ducati ST3s ABS Bearing Crankcase halves 702.4.020.1A 2006 Ducati SuperSport 1000 Bearing Crankcase halves 702.4.020.1A 2007 Ducati 1098 Bearing Crankcase halves 702.4.020.1A 2007 Ducati 1098s Bearing Crankcase halves 702.4.020.1A 2007 Ducati Monster S2r 1000 Bearing Crankcase halves 702.4.020.1A 2007 Ducati Monster S4r Bearing Crankcase halves 702.4.020.1A 2007 Ducati Monster S4rs Bearing Crankcase halves 702.4.020.1A 2007 Ducati Multistrada 1100 Bearing Crankcase halves 702.4.020.1A 2007 Ducati Multistrada 1100s Bearing Crankcase halves 702.4.020.1A 2007 Ducati SportClassic 1000 Sport Biposto Bearing Crankcase halves 702.4.020.1A 2007 Ducati SportClassic 1000s Sport Bearing Crankcase halves 702.4.020.1A 2007 Ducati SportClassic GT1000 Bearing d.m.m.033434 Crankcase halves 702.4.020.1A 2007 Ducati ST3 Bearing Crankcase halves 702.4.020.1A 2007 Ducati ST3s ABS Bearing Crankcase halves 702.4.020.1A 2008 Ducati 1098 Bearing Crankcase halves 702.4.020.1A 2008 Ducati 1098r Bearing Crankcase halves 702.4.020.1A 2008 Ducati 1098s Bearing Crankcase halves 702.4.020.1A 2008 Ducati Monster S2r 1000 Bearing Crankcase halves 702.4.020.1A 2008 Ducati Monster S4r Bearing Crankcase halves 702.4.020.1A 2008 Ducati Monster S4rs Bearing Crankcase halves 702.4.020.1A 2008 Ducati Multistrada 1100 Bearing Crankcase halves 702.4.020.1A 2008 Ducati Multistrada 1100s Bearing Crankcase halves 702.4.020.1A 2008 Ducati SportClassic 1000 Sport Biposto Bearing Crankcase halves 702.4.020.1A 2008 Ducati SportClassic 1000s Sport Bearing Crankcase halves 702.4.020.1A 2008 Ducati SportClassic GT1000 Bearing d.m.m.033434 Crankcase halves 702.4.020.1A 2009 Ducati 1098r Bearing Crankcase halves 702.4.020.1A 2009 Ducati 1098r Bayliss Bearing Crankcase halves 702.4.020.1A 2009 Ducati 1198 Bearing Crankcase halves 702.4.020.1A 2009 Ducati 1198s Bearing Crankcase halves 702.4.020.1A 2009 Ducati Multistrada 1100 Bearing Crankcase halves 702.4.020.1A 2009 Ducati Multistrada 1100s Bearing Crankcase halves 702.4.020.1A 2009 Ducati SportClassic GT1000 Bearing Crankcase halves 702.4.020.1A 2009 Ducati SportClassic 1000s Sport Bearing Crankcase halves 702.4.020.1A 2010 Ducati 1198 Bearing Crankcase halves 702.4.020.1A 2010 Ducati 1198r Corse Bearing Crankcase halves 702.4.020.1A 2010 Ducati 1198s Bearing Crankcase halves 702.4.020.1A 2010 Ducati 1198s Corse Bearing Crankcase halves 702.4.020.1A 2010 Ducati Multistrada 1200 Bearing Crankcase halves 702.4.020.1A 2010 Ducati Multistrada 1200 ABS Bearing Crankcase halves 702.4.020.1A 2010 Ducati Multistrada 1200s ABS Bearing Crankcase halves 702.4.020.1A 2010 Ducati Multistrada 1200s Sport Bearing Crankcase halves 702.4.020.1A 2010 Ducati Multistrada 1200s Touring Bearing Crankcase halves 702.4.020.1A 2010 Ducati SportClassic GT1000 Bearing Crankcase halves 702.4.020.1A 2010 Ducati Streetfighter Bearing Crankcase halves 702.4.020.1A 2010 Ducati Streetfighter S Bearing Crankcase halves 702.4.020.1A 2011 Ducati 1198 Bearing Crankcase halves 702.4.020.1A 2011 Ducati 1198 SP Bearing Crankcase halves 702.4.020.1A 2011 Ducati Multistrada 1200 Bearing Crankcase halves 702.4.020.1A 2011 Ducati Multistrada 1200 ABS Bearing Crankcase halves 702.4.020.1A 2011 Ducati Multistrada 1200 Touring Bearing Crankcase halves 702.4.020.1A 2011 Ducati Streetfighter Bearing Crankcase halves 702.4.020.1A 2011 Ducati Streetfighter S Bearing Crankcase halves 702.4.020.1A 2012 Ducati Diavel Bearing Crankcase halves 702.4.020.1A 2012 Ducati Diavel Carbon Bearing Crankcase halves 702.4.020.1A 2012 Ducati Multastrada 1200 Touring Bearing Crankcase halves 702.4.020.1A 2012 Ducati Multistrada 1200 Bearing Crankcase halves 702.4.020.1A 2012 Ducati Multistrada 1200s Bearing Crankcase halves 702.4.020.1A 2012 Ducati Multistrada 1200s Pikes Peak Bearing Crankcase halves 702.4.020.1A 2012 Ducati Streetfighter S Bearing Crankcase halves 70240201A 2013 Ducati Streetfighter S BEARING CRANKCASE BEARINGS 70240201A 2014 Ducati Monster 696 BEARING CRANKCASE 75191.3380 2001 Ducati 748 Bearing HALF CRANKCASES 75191.3380 2001 Ducati 748r Bearing HALF CRANKCASES 75191.3380 2001 Ducati 996 Biposto Bearing HALF CRANKCASES 75191.3380 2001 Ducati 996r Bearing HALF CRANKCASES 75191.3380 2001 Ducati MH900 Evoluzione Bearing HALF CRANKCASES 75191.3380 2001 Ducati Monster 400 Bearing HALF CRANKCASES 75191.3380 2001 Ducati Monster 600 Bearing HALF CRANKCASES 75191.3380 2001 Ducati Monster 750 Bearing HALF CRANKCASES 75191.3380 2001 Ducati Monster 900 Bearing HALF CRANKCASES 75191.3380 2001 Ducati Monster S4 Bearing HALF CRANKCASES 75191.3380 2001 Ducati ST2 Bearing HALF CRANKCASES 75191.3380 2001 Ducati ST4 Bearing HALF CRANKCASES 75191.3380 2001 Ducati ST4s Bearing HALF CRANKCASES 75191.3380 2001 Ducati SuperSport 750 Bearing HALF CRANKCASES 75191.3380 2001 Ducati SuperSport 900 Bearing HALF CRANKCASES 75191.3380 2002 Ducati 748 Bearing HALF CRANKCASES 75191.3380 2002 Ducati 748r Bearing HALF CRANKCASES 75191.3380 2002 Ducati 748s Bearing HALF CRANKCASES 75191.3380 2002 Ducati 998 Bearing HALF CRANKCASES 75191.3380 2002 Ducati 998s Bearing HALF CRANKCASES 75191.3380 2002 Ducati 998s Bayliss Bearing HALF CRANKCASES 75191.3380 2002 Ducati 998s Bostrom Bearing HALF CRANKCASES 75191.3380 2002 Ducati MH900e Bearing HALF CRANKCASES 75191.3380 2002 Ducati MH900e Bearing HALF CRANKCASES 75191.3380 2002 Ducati Monster 400 Bearing HALF CRANKCASES 75191.3380 2002 Ducati Monster 620 Bearing HALF CRANKCASES 75191.3380 2002 Ducati Monster 620s Bearing HALF CRANKCASES 75191.3380 2002 Ducati Monster 750 Bearing HALF CRANKCASES 75191.3380 2002 Ducati Monster 900 Bearing HALF CRANKCASES 75191.3380 2002 Ducati Monster 900 Bearing HALF CRANKCASES 75191.3380 2002 Ducati Monster S4 Bearing HALF CRANKCASES 75191.3380 2002 Ducati ST4 Bearing HALF CRANKCASES 75191.3380 2002 Ducati ST4s Bearing HALF CRANKCASES 75191.3380 2002 Ducati SuperSport 750 Bearing HALF CRANKCASES 75191.3380 2002 Ducati SuperSport 750 Sport Bearing HALF CRANKCASES 75191.3380 2002 Ducati SuperSport 900 Bearing HALF CRANKCASES 75191.3380 2002 Ducati SuperSport 900 Sport Bearing HALF CRANKCASES 75191.3380 2003 Ducati 748 Bearing HALF CRANKCASES 75191.3380 2003 Ducati 749 Bearing HALF CRANKCASES 75191.3380 2003 Ducati 998 Bearing HALF CRANKCASES 75191.3380 2003 Ducati 999 Bearing HALF CRANKCASES 75191.3380 2003 Ducati 999r Bearing HALF CRANKCASES 75191.3380 2003 Ducati 999s Bearing HALF CRANKCASES 75191.3380 2003 Ducati Monster 1000s Bearing HALF CRANKCASES 75191.3380 2003 Ducati Monster 620 Bearing HALF CRANKCASES 75191.3380 2003 Ducati Monster 620s Bearing HALF CRANKCASES 75191.3380 2003 Ducati Monster 800s Bearing HALF CRANKCASES 75191.3380 2003 Ducati Monster S4r Bearing HALF CRANKCASES 75191.3380 2003 Ducati Multistrada 1000 Bearing Crankcase halves 75191.3380 2003 Ducati ST2 Bearing HALF CRANKCASES 75191.3380 2003 Ducati ST4 Bearing HALF CRANKCASES 75191.3380 2003 Ducati ST4s Bearing HALF CRANKCASES 75191.3380 2003 Ducati ST4s ABS Bearing HALF CRANKCASES 75191.3380 2003 Ducati SuperSport 1000 Bearing HALF CRANKCASES 75191.3380 2003 Ducati SuperSport 620 Sport Bearing HALF CRANKCASES 75191.3380 2003 Ducati SuperSport 800 Bearing HALF CRANKCASES 75191.3380 2003 Ducati SuperSport 800 Sport Bearing HALF CRANKCASES 75191.3380 2004 Ducati 749 Dark Bearing HALF CRANKCASES 75191.3380 2004 Ducati 749r Bearing CRANKCASE HALVES 75191.3380 2004 Ducati 749s Bearing HALF CRANKCASES 75191.3380 2004 Ducati 999 Bearing HALF CRANKCASES 75191.3380 2004 Ducati 999r Bearing HALF CRANKCASES 75191.3380 2004 Ducati 999s Bearing HALF CRANKCASES 75191.3380 2004 Ducati Monster 1000 Bearing HALF CRANKCASES 75191.3380 2004 Ducati Monster 620 Bearing CRANKCASE HALVES 75191.3380 2004 Ducati Monster 800 Bearing HALF CRANKCASES 75191.3380 2004 Ducati Monster S4r Bearing HALF CRANKCASES 75191.3380 2004 Ducati Multistrada 1000 Bearing Crankcase halves 75191.3380 2004 Ducati ST4s ABS Bearing HALF CRANKCASES 75191.3380 2004 Ducati SuperSport 1000 Bearing HALF CRANKCASES 75191.3380 2004 Ducati SuperSport 800 Bearing HALF CRANKCASES 75191.3380 2005 Ducati 749 Dark Bearing HALF CRANKCASES 75191.3380 2005 Ducati 749r Bearing CRANKCASE HALVES 75191.3380 2005 Ducati 749s Bearing HALF CRANKCASES 75191.3380 2005 Ducati 999r Bearing HALF CRANKCASES 75191.3380 2005 Ducati 999s Bearing HALF CRANKCASES 75191.3380 2005 Ducati Monster 1000 Bearing HALF CRANKCASES 75191.3380 2005 Ducati Monster 1000s Bearing HALF CRANKCASES 75191.3380 2005 Ducati Monster 400 Bearing CRANKCASE HALVES 75191.3380 2005 Ducati Monster 620 Bearing CRANKCASE HALVES 75191.3380 2005 Ducati Monster 620 Dark Bearing CRANKCASE HALVES 75191.3380 2005 Ducati Monster 620 Dark Single Disc Bearing CRANKCASE HALVES 75191.3380 2005 Ducati Monster S2r Bearing CRANKCASE HALVES 75191.3380 2005 Ducati Monster S2r Dark Bearing HALF CRANKCASES 75191.3380 2005 Ducati Monster S4r Bearing HALF CRANKCASES 75191.3380 2005 Ducati ST3 Bearing HALF CRANKCASES 75191.3380 2005 Ducati ST4 Bearing HALF CRANKCASES 75191.3380 2005 Ducati ST4s ABS Bearing HALF CRANKCASES 75191.3380 2005 Ducati SuperSport 1000 Bearing HALF CRANKCASES 75191.3380 2006 Ducati 749r Bearing CRANKCASE HALVES 75191.3380 2006 Ducati 749s Bearing CRANKCASE HALVES 75191.3380 2006 Ducati 999 Bearing Crankcase halves 75191.3380 2006 Ducati 999r Bearing Crankcase halves 75191.3380 2006 Ducati 999r Xerox Bearing Crankcase halves 75191.3380 2006 Ducati 999s Bearing Crankcase halves 75191.3380 2006 Ducati Monster S2r 1000 Bearing Crankcase halves 75191.3380 2006 Ducati Monster S4r Bearing Crankcase halves 75191.3380 2006 Ducati Monster S4rs Bearing Half Crankcases 75191.3380 2006 Ducati Multistrada 1000 Bearing Crankcase halves 75191.3380 2006 Ducati Multistrada 1000s Bearing Crankcase halves 75191.3380 2006 Ducati Multistrada 620 Bearing f.m.m.013216 Crankcase halves 75191.3380 2006 Ducati Multistrada 620 Dark Bearing f.m.m.013216 Crankcase halves 75191.3380 2006 Ducati SportClassic 1000 Paul Smart Limited Edition Bearing Crankcase halves 75191.3380 2006 Ducati SportClassic 1000 Sport Bearing Crankcase halves 75191.3380 2006 Ducati ST3 Bearing Crankcase halves 75191.3380 2006 Ducati ST3s ABS Bearing Crankcase halves 75191.3380 2006 Ducati SuperSport 1000 Bearing Crankcase halves 75191.3380 2007 Ducati 1098 Bearing Crankcase halves 75191.3380 2007 Ducati 1098s Bearing Crankcase halves 75191.3380 2007 Ducati Monster S2r 1000 Bearing Crankcase halves 75191.3380 2007 Ducati Monster S4r Bearing Crankcase halves 75191.3380 2007 Ducati Monster S4rs Bearing Crankcase halves 75191.3380 2007 Ducati Multistrada 1100 Bearing Crankcase halves 75191.3380 2007 Ducati Multistrada 1100s Bearing Crankcase halves 75191.3380 2007 Ducati SportClassic 1000 Sport Biposto Bearing Crankcase halves 75191.3380 2007 Ducati SportClassic 1000s Sport Bearing Crankcase halves 75191.3380 2007 Ducati SportClassic GT1000 Bearing d.m.m.033434 Crankcase halves 75191.3380 2007 Ducati ST3 Bearing Crankcase halves 75191.3380 2007 Ducati ST3s ABS Bearing Crankcase halves 75191.3380 2008 Ducati 1098 Bearing Crankcase halves 75191.3380 2008 Ducati 1098r Bearing Crankcase halves 75191.3380 2008 Ducati 1098s Bearing Crankcase halves 75191.3380 2008 Ducati Monster S2r 1000 Bearing Crankcase halves 75191.3380 2008 Ducati Monster S4r Bearing Crankcase halves 75191.3380 2008 Ducati Monster S4rs Bearing Crankcase halves 75191.3380 2008 Ducati Multistrada 1100 Bearing Crankcase halves 75191.3380 2008 Ducati Multistrada 1100s Bearing Crankcase halves 75191.3380 2008 Ducati SportClassic 1000 Sport Biposto Bearing Crankcase halves 75191.3380 2008 Ducati SportClassic 1000s Sport Bearing Crankcase halves 75191.3380 2008 Ducati SportClassic GT1000 Bearing d.m.m.033434 Crankcase halves 75191.3380 2009 Ducati 1098r Bearing Crankcase halves 75191.3380 2009 Ducati 1098r Bayliss Bearing Crankcase halves 75191.3380 2009 Ducati 1198 Bearing Crankcase halves 75191.3380 2009 Ducati 1198s Bearing Crankcase halves 75191.3380 2009 Ducati Multistrada 1100 Bearing Crankcase halves 75191.3380 2009 Ducati Multistrada 1100s Bearing Crankcase halves 75191.3380 2009 Ducati SportClassic GT1000 Bearing Crankcase halves 75191.3380 2009 Ducati SportClassic 1000s Sport Bearing Crankcase halves 75191.3380 2010 Ducati 1198 Bearing Crankcase halves 75191.3380 2010 Ducati 1198r Corse Bearing Crankcase halves 75191.3380 2010 Ducati 1198s Bearing Crankcase halves 75191.3380 2010 Ducati 1198s Corse Bearing Crankcase halves 75191.3380 2010 Ducati Multistrada 1200 Bearing Crankcase halves 75191.3380 2010 Ducati Multistrada 1200 ABS Bearing Crankcase halves 75191.3380 2010 Ducati Multistrada 1200s ABS Bearing Crankcase halves 75191.3380 2010 Ducati Multistrada 1200s Sport Bearing Crankcase halves 75191.3380 2010 Ducati Multistrada 1200s Touring Bearing Crankcase halves 75191.3380 2010 Ducati SportClassic GT1000 Bearing Crankcase halves 75191.3380 2010 Ducati Streetfighter Bearing Crankcase halves 75191.3380 2010 Ducati Streetfighter S Bearing Crankcase halves 75191.3380 2011 Ducati 1198 Bearing Crankcase halves 75191.3380 2011 Ducati 1198 SP Bearing Crankcase halves 75191.3380 2011 Ducati Multistrada 1200 Bearing Crankcase halves 75191.3380 2011 Ducati Multistrada 1200 ABS Bearing Crankcase halves 75191.3380 2011 Ducati Multistrada 1200 Touring Bearing Crankcase halves 75191.3380 2011 Ducati Streetfighter Bearing Crankcase halves 75191.3380 2011 Ducati Streetfighter S Bearing Crankcase halves 75191.3380 2012 Ducati Diavel Bearing Crankcase halves 75191.3380 2012 Ducati Diavel Carbon Bearing Crankcase halves 75191.3380 2012 Ducati Multastrada 1200 Touring Bearing Crankcase halves 75191.3380 2012 Ducati Multistrada 1200 Bearing Crankcase halves 75191.3380 2012 Ducati Multistrada 1200s Bearing Crankcase halves 75191.3380 2012 Ducati Multistrada 1200s Pikes Peak Bearing Crankcase halves 75191.3380 2012 Ducati Streetfighter S Bearing Crankcase halves 751913380 2013 Ducati Streetfighter S BEARING CRANKCASE 751913380 2014 Ducati Monster 696 BEARING CRANKCASE
