The tank is off, the tubes are off, the filler cap is open. No matter which way I turn, shake or slosh the bloody thing, there is a litre at least that won't come out. Help!
I don't have a spanner on me big enough. Siphoning is not getting the last bit out. It's got 4 possible exit points currently and is being well stubborn
A 900mm length of windscreen washer hose should be able to get into the lowest corner easily, if you have angled the tank to get all the fuel into one point.........and get the tank high enough above the other end of the hose.
I have cut the wires. It's off the bike. I stuffed some sheetin there but it doesn't work. I'm sending it with the tubes taped up and wrapped in a bin liner so Parcelforce don't smell anything dodgy.
Lucky you cut the green wire first............if you had cut the white wire, well........... ...........that would have been the end of the world..... (Why did you have to cut the wires and why couldn't you get the fuel out?...........FFS?)
I'm pretty sure that's what I used on my SSie, but I guess Ducati may have changed the tank design from one batch to another? Either that or the fuel gauge sensor opens up a big hole when removed. Or as per TT600:
