How Do You Know If Your Front Forks Are Bent..
Discussion in 'Suspension help' started by NOODS X, Sep 3, 2020.
  1. Hypothetical Q here but if you buy a set of used forks say or a damaged bike how can you be assured your forks are straight other than the obv damage signs etc?
    X
  2. Send them to motoliner mate
  3. Clamp the leg in a vice with nylon half shells to protect, put a dti or similar on the lower and rotate. Do this at various point along. There should be minimal deflection on the clock.
  4. Or just roll them out flat on a true sheet metal workers bench.
  5. The caliper brackets tend to hinder that idea.
  6. Overhang the caliper bracket end over the edge of the world / table.:thinkingface:
  7. Still wont sit flat unless your take them apart
  8. V-blocks and a dti is another way
  9. Ok then put them alongside each other then.
  10. Yeah, that'll be ok :upyeah:
  11. Thanks guys that makes sense.. x
