how to adjust chain multi 1000
Discussion in 'Multistrada' started by paulfastbikes, Sep 5, 2012.
  1. can someone talk me through how to adjust my chain on my old multi 1000 have no manual cheers:biggrin:
  2. Owner manuals available here for download in pdf format:
    Ducati
  3. so its says take it to dealer !
  4. Ah yes so it does!:rolleyes:....do you have a big c spanner?
  5. Slacken the two 14mm A/F bolts and grasping the Sprocket/chain guard with both hands try to rotate to achieve the tension.
    Retighten the 14mm A/F (across flats)bolts carefully ...nip 1 then 2 now tighten to torque 1 then 2 then 1 again as tightening 2 will have affected 1
    Much easier with big C spanner though
    tension should be achieved whilst on side stand
    #5 Android, Sep 5, 2012
