Hi experts, i need your help. How can i check if fuel is transported to the fuel injectors on a 888. I would like to make this check first before i fiddle around with the injectors. Any help is welcome. Greetings Thomas
Prop up the tank, remove the air filter top and filter, then look down the throttle bodies whilst hitting the start button. If fuel is getting there you'll be able to see it squirting out of the injectors. Steve R
