I want to get the forks off for maitenance, change the oil for lighter stuff etc. I dont have a front yolk stand but will get a rear stand. Using the rear stand to stabalised the bike upright can I put a jack under the engine to remove the forks. Has anyone used this method.
Yep, used that method in the past many times but make sure you don't raise the jack too far as it will de stabilise the rear stand! I also used a shaped piece of wood that fits the sump angle placed on the jack. You only need the wheel just off the ground, goes without saying really but make sure the bike is stable before taking wheel and forks out and make sure you don't knock into the bike!
