Hypermotard 950 Rve Front Settings
Discussion in 'Suspension help' started by CP012, May 8, 2021.
  1. Hi all,
    When I’m riding my right hand is going to sleep after about 15 minutes which means I have to keep rolling off to shake it off (clearly not ideal on a road). I’ve just fitted some grip puppies which are supposed to absorb vibration and stop it from happening. I’m also going to try and drop the tyre pressures by 1-2 psi. I’ve just attempted to soften the front up from the factory settings slightly by taking off a couple of clicks of compression but there’s no clicks when I make the adjustment. I’ve done it by quarter turns from the base setting but why would there not be any clicks? Every bike I’ve owned when you make suspension adjustments there has been clicks that you can count. Does this mean there is an issue with the internals or is this normal for the Marzocchi forks? Never owned a Ducati before or had this make of forks?
