Hi. Ive posted here as this one might be more of a general question. As above... Can i buy the connectors on thier own. Specifically the indicator plugs.... Collecting my evo sp Tuesday and the front hanguards/indicators are missing so ive got some to go on. My handguards are missing the plugs and I'm pretty sure the plugs on the loom will have gone as well.... Anyone know where I can buy them?
This place has male and female pigtails. If you buy just the connections you'd need a small w crimp tool, which, unless you've got one handy are quite expensive. Ducati Indicator Black Connector Turn Signal Leads
Brilliant... Although i can only see the males.... I'm sure the "loomside" connectors will be missing!
I bought some male and female connectors from here: Ducati - KTM turn signal connectors I was able to crimp them without the specific crimp tool. They are much cheaper to buy individually than the pre-made "pigtails".
Thanks, but, those aren't the right ones.... They're what's called deustchplugs.... I'm trying to return it to the stock wiring...
Oh. The ones I used are standard on M1100 and 1098 indicators - little white mini plugs...I assumed that they would be the same on the HM.
