I've just bought some Oberon bar end indicators. There are no connectors supplied. Does anyone know what the standard indicator connectors are called and where can I get them? Anyone fitted the Oberon bar end indicators?
http://www.bikesportdevelopments.co.uk/ProductDetails.asp?ProductCode=C32C-DU1 There's also someone who sell's connectors with wiring, I'll post up a link when I find it.
Scroll down the page, they're called "pig tails" http://kojaycat.co.uk/epages/950000...ion=View&ObjectID=14170093&PageSize=30&Page=2
Excellent, that's a real result. Just what I need. Easier to solder the pig tails than the plugs themselves. Thanks v much. I'll order them today.
I may resort to these but with the oem indicator plugs, is it possible to remove the pins? I need to feed the wire through a small gap and the plug is too wide!
As far as I remember, I didn't try to remove the pins. Someone else may be able to help you on that one. I do remember figuring that I had to thread the wires through the bars and the cap at the top end of the bar. Therefore I threaded it all through then soldered the pig tails(I.e.cables with new connectors) in position. Obviously being v careful by covering the bike so no solder or flux could damage anything. I figured it was easier to do this than piss around with the original plugs n pins and probably wind up damaging them resulting having to buy new ones anyway. Heat shrinked them and had no problems. Hope it helps.
