For Sale Iscan Obdstar
Discussion in 'Parts, Accessories & Clothing For Sale' started by NBB, Oct 1, 2025 at 9:12 PM.
  1. The OBDSTAR iScan for DUCATI Motorcycle IMMO Progarmming OBD2 Diagnostic Scanner is a user-friendly and efficient tool designed specifically for motorcycles. With its simple and intuitive menu guidance, it provides complete diagnostic functions for quick and accurate fault location. The scanner connects via cable to the motorcycle's OBD, CAN, OBDII, and EOBD interfaces, and features an LCD display for easy viewing. Its new android operating system allows for code reading, code clearing, data flow, action test, and setting, making it a versatile and reliable option for motorcycle maintenance and repair.
    Used only a couple of times to code heated grips and quick shifter on my Ducati Monster. Also reset the exhaust valve motor when returning the bike to std after removing a full Termignoni system. Item is in mint as new condition.
    Worth noting these do not come with a UK plug; I used a travel plug adapter to charge it when required. Has earlier and later plugs to connect to the OBD.
    £200 delivered.
    IMG_4877.jpeg IMG_4878.jpeg IMG_4879.jpeg IMG_4880.jpeg IMG_4881.jpeg IMG_4882.jpeg IMG_4883.jpeg IMG_4884.jpeg IMG_4885.jpeg IMG_4886.jpeg IMG_4887.jpeg IMG_4888.jpeg IMG_4889.jpeg
  2. Yes please, I’ll take this!
  3. Ooooo you bugger, you beat me to it by just a couple of minutes.
  4. Messaged you back
  5. #5 NBB, Oct 1, 2025 at 10:26 PM
