Hello all - I'm on the lookout for a pair of IW-031 (green) injectors (888,ST2,900ssie/750ssie, probably others too).. online sellers seem to be full of what looks like non-original copies. I'd normally avoid such obvious knock-offs, particular on a fuel related component, but I'm aware that these injectors are no longer available. Has anyone got any positive experience of using these? Thanks, Mike
Cool - thanks Nelly - Perhaps the early 916/748, I think the later ones used side-feed injectors, rather than the top feed ones.
Hi Derek - There's a few used ones on ebay, some of which look a bit erm, well - used, and I also found I found a few new ones while looking - these are the cheapest new ones I've found, that don't look like the copies - https://www.bielstein.com/Injector-IW031-Magnet-Marelli-coupe-Fiat-2000ccm-16-V Stein Dinse are normally my go-to location, but not at this price... https://www.stein-dinse.biz/eliste/eliste_shopartikel.php?id=8ce6c80&ar=329646 I can also give Geoff Baines a call, he has been extraordinarily helpful in tracking stuff down in the past - but I'll wait to see the outcome of Nelly's kind offer to check. These are to go into the Bim DB2 that I was telling you about a few days ago.. I've come to realise that the IW-042 reds that it currently has will run out of time pretty quickly at large throttle openings. Moving to greens will resolve that...
Might it be possible to pick up a set of throttle bodies for ST2, SSie etc. they don't usually fetch much, especially something like 7500SSie. They are still available new from Ducati but expensive... £270 a piece
Gosh - like busses indeed, sorry I hadn't spotted that other thread. I've just bought a used pair from ebay for £75, so hopefully I should be sorted now..
