K Bike Slipper Clutch Issues
Discussion in 'Technical Help' started by Ryan, Jan 26, 2018.
  1. Hi i fitted my K bike slipper clutch today.
    I have an issue tho my clutch lever has no compression at all now and the springs arnt moving on the clutch its like its no connected at all but i have fitted the rod in correctly.
    Has anyone any idea?
  2. Have you removed the rod from the clutch side? Some slave cylinders require a small spacer to be fitted to the end of the rod at the slave cylinder end, if you have removed the rod from the clutch side this spacer may have dropped out of position.
    Just a thought to start with.
    Steve
  3. ah okay i will check that i take it i would remove the slave cylinder and check it hasn't falling out of position that side?
    I have an after market Ducabike slave cylinder.
  4. I haven't got one with the spacer myself so I don't know how it's held in place, but it's worth a look.
    Steve
