Left Hand Brembo Caliper
Discussion in 'Wanted' started by comfysofa, Oct 1, 2014.
  1. As above I need one for my supermoto build....don't really care which one it is, monoblock would be nice. Cheers.
  2. I have a pair available - put two on!
    Mine are Radial as fitted to 999R's and Aprilia RSV-R Factory
    Didn't really want to split them though :(
  3. Only got one disc....radial is what I want - found someone that does a caliper/spacer mount machined from a lump of billet that'll hold it....I really only do need one - how much do you want for both??
  4. £200 seems cheap having a quick look on Ebay with a £10 to cover insured delivery.
  5. Yep - seems fine - are they monoblock jobbies? doesn't really matter - just curious (doesn't really matter as if I can get this working itll give me more stopping power than ever was on there before)....can you bear with me - the only reason I ask is im waiting for the lad that's supplying the lump of billet to come back to me....I just need to a. verify the measurement as the brembo that he's picturing is one off a KTM 990 - im guessing they are but just need to check....and the other is that ive not agreed the payment terms with him yet (ie - I want to make sure its definitely on the way) - that ok with you??
  6. Yep, they are not advertised other than on here but I will hold for a while for you.
    In the mean time I will get some photo's - not mono blocks no, but some people call them as such in error.
  7. Yeah - my factory has monoblocks - I wasn't sure what the R came with....as I say doesn't matter as one of those bad boys will stop my 525 easily...cheers - ill just flog the other on its own - im guessing someone somewhere will have the unfortunate task of replacing stuff after a slide...
  8. To follow up on those who may be in error...999/749R radial calipers are NOT "monoblock"....(well mine aren't).
  9. None are :Happy:
  10. Am I right in assuming that the model of the bike is kind of irrelevant - the phrase monoblock means that the caliper is cast from one lump - no matter what bike it comes off of....
  11. Yes, exactly right...
  12. Photo's
    Please note, it was not my intention that they look like a couple of angry frogs in the last picture...
    There's approx. 3mm on the Pads.
  13. Angry Frogs...is there an App for that?
  14. There's an App for everything apparently
