Lifting Pantah 600 Rear Cylinder With Engine In Frame?
Discussion in 'Vintage' started by Eran Kaufman, Nov 24, 2022.
  1. Hey guys,
    After putting the engine back tougher (replaced piston rings) and putting all back in the bike, when i started for the first time there's an oil leak from the rear Cylinder base gasket, apparently it got distorted somehow during assembly and i didn't notice.
    i really don't want to take the engine out again, is it possible to replace the gasket with the engine in place?
    i thought maybe to take out all the mounting bolts and tilt the engine down using the swing arm shaft as a pivot (all carbs,fuel tank etc removed) can this work?
