Loose Controls
Discussion in 'Technical Help' started by midlifecrisis, Sep 20, 2020.
  1. The left hand controls on my 2002 Monster 750ie are loose and can rotate By around 10 degrees around the bars, especially if I use the choke/fast idle lever. I have tightened the securing bolts as much as I can but it still swivels. Anyone have any suggestions to stop this happening?
  2. has a locating screw rattled out? Or, has a bit of WD40 been going on - well, a lot of WD40?
  3. Standard set-up nearly always have a plastic "dowel" in moulded switch and corresponding hole in handlebars but there were some exceptions. If it's had aftermarket handlebars then maybe diameter is slightly smaller It's a botch-up, but you could wrap a couple of turns of insulation tape/masking tape around bar as a temporary fix.
  4. Thanks for the speedy reply - I didn’t know about the locating dowel. I think the bars are original but perhaps the dowel has broken off. I will strip off the switch cluster and see what’ it’s like inside.
