Loose Rear Wheel C Ring\ pin
Discussion in 'Technical Help' started by Dubs, Jul 25, 2013.
  1. Notced thus just now, it just came off
    Us it ok to rude without?
  2. What are you referring to? The clip that holds the nut in place? If so I once had a factory titanium wheel nut that didn't have any means to insert the clip/pin so what I did was loop some wire through the two spindle holes over and over to stop the nut unwinding... never moved
  3. Allo Allo what have we here then, I cant see anything missing although if you are referring to the safety clip around the nut it's better to secure it with a tiewrap through the two loops to stop it coming off.
    Steve
  4. Cheers lads. Sorted with tie clip.
    Nice one!
