Lost my smart key , what a twat ! anyway can anybody tell me cost and procedure to get a replacement please
I lost mine a year ago. Order via your dealer- £100 to replace - ouch especially as the old one turned up 3 weeks later.
The time to order a spare key is when you don't need it. Then you are prepared. After you have lost your main key is a bit late.
I have a plain key so at least I can open the fuel cap and panniers whilst using the secret starting code. Hopefully I will never need it !
You should also have had a red key which will allow you to start the bike normally, without entering the PIN, if you hold it close to the antenna under the dash.
If I carried the red key, with me that would Im sure be true. But its safely stored in the manual in the house
On the DVT, it's under the black cover to the right of the dash. On the pre-DVT, it's behind the dash display itself.
