Low Rev Missfire 900ssie
Discussion in 'Supersport (1974-2007)' started by GordonH, Sep 7, 2018.
  1. I get a very intermittent low rev "soft" missfire on my 900ss ie. Almost a sense of a slight blowback via the airbox as well.
    Noticeable sometimes when pulling away in first gear at the point where the clutch is fully engaged. Sometimes it will do the same when accelerating from low rev in other gears. It is really intermittent - ie might notice it two or three times on a 50 mile ride.
    Any ideas?
  2. Sounds like the sort of thing that might have to get worse before you can pin it down.
  3. when were the sparkplugs last changed …...also check in the tank if there is any water in there
    check the easy things first
