Hi all. Would it be possible for an owner of one of these models to measure the length between the master cylinder and a calliper banjo centre and post the result please? I am trying to find out what length a race pair of lines for an M900 would be, to see if they are compatible with my bike. Cheers, Rik.
Hi Rik I'm not sure what you are intending Re:hose junction for R/H and L/H calipers (i.e. 'T' part way along route or two separate runs/double banjo on Master cylinder) as standard set-up uses a 'junction bar' with a tapping for the hydraulic brake light switch in the middle (as you probably know). Anyway, taking a 'happy' route straight to the R/H caliper I make it 750 mm so you need to add between 100 - 150 mm to that for the L/H caliper if you are going for a double banjo set-up.
