M900 Marzocchi Inner Fork Tube Or Pair Showa Forks
Discussion in 'Wanted' started by Nasher, Jun 22, 2020.
  1. I need a new, or undamaged, inner fork tube for the Right Hand side of my adjustable Marzocchi equipped 97 M900.
    Either just the tube, or a whole fork leg.
    Although I do need to work out how to remove the casting from the bottom of the leg.
    I believe the inner leg is the same on the LHS so could use one of those as well I believe.
    What's anyone got hanging around?
    Am also open to a complete set of Showas, but must be the early 40mm caliper mounting bolt hole type
    Nasher.
  2. Anyone?
    Either RHS Marzocchi leg or a complete pair of adjustable Showa forks.
    Adjustable
    40mm Caliper Bolt hole centres.
    17mm axle
    54mm/50mm Yokes.
    Don't mind rebuilding them, as at least the Showas come apart!
    Thanks
    Nasher
