1200 S Mid Pipe
Discussion in 'Monster' started by PAUL HARRIS, May 11, 2022.
  1. Can you buy the mid pipe so you can keep the original headers and still use the Termi's or standard can.
    Just as way of getting rid of the flapper valve (i know you can remove the flap) but wanted a cleaner look.
  2. If you want clean and functional, could always take it to an exhaust shop, get them to cut off the part of the pipe with the valve and weld in a piece of matching diameter stainless steel pipe, I believe that’s what Ducati use for their exhaust pipes.
    If you are worried how it will look after, get the whole pipe polished, or cera coated or another finish to make it all look even.
