Misfire At Low Revs - Any Ideas Please?
Discussion in 'Ducati General Discussion' started by Ian, Aug 13, 2019.
  1. Hi,
    My 851 broke cover today and went for a decent ride. It’s now developed an inability to run well below about 3,500 rpm - it feels and sounds like it’s just running on the one cylinder. It’s also popping and banging just about constantly on the over-run. It pulls fantastically well above 4,000, it’s just about about unridable in thirty zones though.
    My initial thought was an air leak into an inlet (when I just had the popping) but I can’t see how this would cause a misfire / non running cylinder at low rpm? Any ideas please?
    Thanks,
    Ian.
    Ps before anyone pipes up who’s seen my opinion in the getting bikes wet discussion - it’s not seen rain today!!!
  2. Tiny split in a tube or air gator? So too much air til it gets some vacuum then it’s shuts the hole? Heard of this on other older Ducati’s.
  3. Excuse my ignorance but what’s a air gator?
  4. Its a really bad description!!
  5. A couple of years ago I had the same problem with my 907ie, which uses the same injection system as the 851. It ran fine at higher revs but at around town speeds it would misfire and cough and splutter. Strangely a new pair of plugs fixed it.
  6. Always worth a try.Wont break the bank either.
  7. Thanks Derek, Keith. I'll start there. Hopefully this thread will soon end and no more posts!
  8. I’m assuming Bradders means the rubber connector between throttle body and inlet valve:thinkingface:
  9. Yep that’s them, so when at lows pressure air seeps in, when at higher revs and pressure it seals again. May be worth a bit of time on a search, as it has defo been discussed on here a few times
  10. New plugs, problem solved. Thanks all!
  11. Nice to get an easy fix :)
