Mivv Decat Pipes - Fitment
Discussion in 'Technical Help' started by JC749, May 6, 2014.
  1. Can anyone confirm which Mivv Decat pipe fits an 05 749 with black swingarm?
    I am coming across all sorts of conflicting info.
    The Mivv website says there are two different decat pipes the C1 and C2 numbers. The C1 being the early 03-04 bikes. It also says "TUBO NO KAT PER COPPA OLIO PRISMATICA" Which means decat pipe for deep sump.
    Exhausts DUCATI - 749
    [​IMG]DUCATI - 749
    2003 >ShareThis
    KitTypeShapeLevelHomologated
    UD.007.C1 (2003-2004)tube no kat------
    TUBO NO KAT PER COPPA 0LIO BASE
    UD.007.C2 (2005-2006)tube no kat----standard level
    UD.007.L2S2 slip-oncarbongpstandard level[​IMG]
    UD.007.L6S2 slip-ontitaniumgpstandard level[​IMG]
    UD.007.LC3 slip-onalloyx-coneunderseat[​IMG]
    UD.007.LXB2 slip-onsteel blackgpunderseat[​IMG]
    Well mine is a shallow sump so does anyone know if the C1 pipe will fit seeing as an 05 will fit an 03 but not vice-versa?
    I did try searching on tinternet but found feck all.
