Monster 620ie Clocks
Discussion in 'Ducati General Discussion' started by Topolino, Oct 28, 2017.
  1. Have a slight issue with the clocks on a Monster 620ie. Basically at key on the needles sweep as normal, all the idiot lights come on and the two LCD displays show all the warnings/text and numbers (888888), however after the self test completes, the LCD digits are only partially showing ie mileage numbers are only showing part of each digit and the "Lo" word in the right hand LCD screen is also partially displayed. Obviously the LCD segments themselves work as they all show up on self test as said, but clearly there is something wrong. The bike was not run for three months following an engine rebuild but nothing was disturbed in the interim and it was working fine up until that point. All the functions via the two pushbuttons can be accessed but again only partially shown (ie current time, trip mileage etc). Bike starts normally and other than the LCD displays appears to be OK. Any ideas or a suitable specialist to contact that you would recommend for advice?
  2. No ideas anyone? BTW I have seen a set of used clocks on Ebay, but assume if mine are damaged (LCD sections) then the replacement clocks will have to be coded to the red key and ECU to make the bike run.
  3. Battery ok? Been known to cause weirder problems.
