Monster Evo Abs - Cam Dialling - Airbox Removal
Discussion in 'Technical Help' started by HYPERBIMDUKE, Feb 13, 2018.
  1. Anyone know if cam dialling can be done with the airbox in situ?
    Dont want to disturb ABS pipework, or can airbox be removed leaving ABS connected/in place?
    Thanks
    Chris
  2. I'm not familiar with this particular model but usually it's possible to undo some of the clips and retaining plates to allow the brake lines to be moved aside, far enough to remove the airbox. Will you need to remove the airbox to get the belt covers off? Usually that's the case but I can't imagine that you'd have to remove the ABS system to get access for a major service.
