Mosfet R/r Question
Discussion in 'Technical Help' started by Pavey, Aug 10, 2016.
  1. I changed the regulator for a Mosfet one on my 1198 and have read the benefit of these ones is they cut out when they get hot, rather than burning out.
    A few times recently while riding i have checked the volts on the dash and they have shown 11.8 ish, other times 13.8 and 14.2.
    Could it be the times i have checked it while it is low were coincidentally times when the r/r was on a cool down period, so in effect not working?
  2. Maybe, but I'd be a bit concerned about the 11.8 figure. The battery voltage should never be that low with a working system.
  3. That's what i'm wondering, does it turn off when hot so is not actually at that time a working system?
  4. It is over-temperature protected so presumably it shuts off if it gets too hot but I wouldn't have thought that it would shut off long enough for the voltage to drop down to 11.8V
  5. Thanks. Must be something else then I presume, loose connection somewhere maybe.
