Moto Guzzi Stelvio Fork Bottom
Discussion in 'Wanted' started by Android853sp, Mar 19, 2016.
  1. I realse that this is a total shot in the dark but my next door neighbour has found that the front axle pinch bolt on the fork bottom has snapped. Some muppet did 3 spot welds on it and rubbed some grease into it to hide it. Any chance someone on here has a Marzocchi fork bottom in a box of bits ? Andy
  2. Is the ally that has broken or the actual broken bolt stuck in the fork bottom?
  3. It's the spindle clamp part of the aluminium fork leg bottom that has snapped. Due to a previous attempt to reattach it with spot welds it's proving to be a challenge to make good a second time although the local welder has made a good enough job to get it through the MoT. Andy
  4. A mate of mine had a similar thing happen on an older Guzzi............he took it to a decent machine shop / welders and although they used the broken 'lug' part for reference, they actually discounted trying to reattach it and they added a blob of ally weld which was then shaped to match the original..........it hardly showed.
