After some recommendations for paddock stands front and rear for Multistrada 1260 2019 model. U.K. sales places please. many thanks
For my 1260 I use an R&G rear stand with the required 40mm pin. For the front I have this one from GhostBikes along with the 27mm pin. Originally purchased these for use with my MV Augusta but only needed to change the rear stand pin to adapt for the Multistrada. The R&G stand I bought off a dealer, who went out of business, for £50, it's a solid piece of kit. The GhostBikes one is at the budget end of the range but is still reasonable. The adjust-ability is useful as by fine tuning the height I can use it in combination with the centre stand if I wish rather than paddock stands at both ends. To use the front stand mentioned above you do need to remove the plastic plate on the underside of the bottom yoke, there are three small cap headed Allen bolts holding it in place.
For front, depends on what for. Under forks ones are ok for most stuff, it’s only removing forks you can’t do. No need to remove any plastics then. Like this https://www.ebay.co.uk/itm/303564778292
