Has anyone come across a workshop / service manual for the Multistrada V2 890cc model (2025-2026)? I picked up my V2S V2S a couple of weeks ago. I've struggled fitting accessories which needed panels removing as this model uses loads of string clips on the plastic panels. It's no obvious where the are so working out how the best way to remove and replace panels is not straightforward. @Rob @El Toro @Ducbird - we really new "V2 890cc" Prefix. Using the "950" prefix isn't ideal as the new V2 890cc 2025+ models have very little in common with the previous 950 / V2 950cc models.
Obviously the sky won't fall I did PM Rob directly and I think he has added V2 to the thread prefix drop down list in the last the day or so. This helps as the 950 prefix was not appropriate for the new 890cc models which have very different engines, frames, bodywork and accessories. Using the V2 prefix still allows for some confusion between the older V2 models (MY 2019-2024) with the 950cc engines and the newer V2 models with the 890cc engines (MY 2025+). So the engine capacity and / or the year of manufacture would ideally need to be added the thread title to avoid confusion. I think there is could be similar of confusion with the Panigale V2 models.
