Multi 1260 Oil Change - Screen Out At 4k Miles?
Discussion in 'Technical Help' started by pcn1, May 3, 2022.
  1. My 2019 Multi only has 4K on the clock and I'm going to do my own oil and filter change.
    Used to do all my own work on the ST2 and Air Cooled multi before.
    I believe this 1260 engine has the oil screen too ? If so, does it need checking/cleaning at this mileage ?
    And if so is there a crush washer required ?
    Thanks
  2. Spoke to Snell's at Alton.
    They said doesn't need looking at unless you see something nasty on the drain plug !
